CyberArk PSM SSH proxy entry
The CyberArk PSM SSH Proxy entry in Remote Desktop Manager offers a seamless way to integrate CyberArk's alternate Privileged Session Manager (PSM) module for secure SSH connections. The entry supports MFA caching (PSM for SSH), which simplifies authentication workflows without compromising security.
Open Remote Desktop Manager.
Add a new entry.
Select the CyberArk PSM SSH Proxy entry.
Fill in the required information:
Under the General section:
Enter the CyberArk server address. Ensure you provide the correct server details, which differ depending on whether you're using Cloud or Self-Hosted environments.
Enter the Username for your CyberArk account.
Enter the Password associated with the account.
Last updated
Was this helpful?
