> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/cyberark-aam-test-certificate-authentication.md).
# CyberArk AAM test certificate authentication
A REST API is an API that complies with the design principles of the REST, or Representational State Transfer, architectural style. REST APIs are therefore sometimes referred to as RESTful APIs.
A convenient way to test CyberArk's Rest API for AAM (Application Access Manager) is from ***Windows Powershell*** or ***Powershell ISE***.
```powershell
#Change location into your personal certificate store.
Set-Location "Cert:\CurrentUser\My\"
#Store the certificate with the thumbprint <your certificate thumbprint> in a variable ($Cert).
$Cert = Get-ChildItem | Where-Object {$_.Thumbprint -eq "<your thumbprint>"}
#Then the Invoke-RestMethod -Method Get...
Invoke-RestMethod -Method Get -Uri "<your Cyberark PasswordVault>AIMWebService/api/Accounts" -Certificate $cert -Body @{AppID = "<Your APP ID>"; Safe = "<Your Safe>"; Object = "<Object name>"}
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/cyberark-aam-test-certificate-authentication.md?ask=<question>&goal=<endgoal>
