> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/create-a-vault-template.md).
# Create a vault template
Create a vault template in Remote Desktop Manager to apply preset options to SQL Server, Devolutions Server, and Devolutions Cloud workspace vaults.
***Vault templates*** are supported on SQL Server, Devolutions Server, and Devolutions Cloud workspaces.
* Go to ***Administration*** – ***System settings*** – ***Vault management*** – ***Vault templates***.
* Click ***Add template***.
* Name the ***vault template*** and set your preferred options template. Click ***OK***.
* When creating a new vault in ***Administration*** – ***Vaults***, select your newly created ***vault template*** from the list.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/create-a-vault-template.md?ask=<question>&goal=<user_goal>
