Copy entries from your user vault to a vault
To be able to copy some entries stored in your user vault to another vault without doing an export/import in Remote Desktop Manager, follow the steps below.
Permissions
Some permissions in Administration – System permissions need to be allowed for standard users:
Copy feature: Enable the Export and Copy Password permissions on the source folder.
Paste feature: Enable Import and Add permissions on the destination folder.
Steps
Select the entries from your user vault that you wish to add to your main vault.
Right-click on your selection.
Select Clipboard – Copy.
Make sure that the Change ID option is checked in the Copy Options window.
Move to your main vault, select the folder in which you wish to add your entries, then right-click on it.
Select Clipboard – Paste.
Your entries should now be copied to the destination vault.
Last updated
Was this helpful?
