> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/copy-buttons-for-custom-fields.md).
# Copy buttons for custom fields
Enable Copy Custom Fields buttons in the Remote Desktop Manager ribbon by hiding custom field values in entry properties.
Copy buttons from the ***Custom Fields*** section of the entries are located under ***Home - Clipboard*** in the Remote Desktop Manager ribbon.
To show the ***Copy Custom Fields*** button in the ***Home*** menu, you need to hide the value of the ***Custom Fields*** in the ***Properties*** of the entry. The value of a hidden custom field is encrypted and protected with the ***View sensitive*** permission.
Changing the ***Custom Field*** tag name will be reflected in the ***Home*** menu tab.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/copy-buttons-for-custom-fields.md?ask=<question>&goal=<user_goal>
