Convert virtual folders in Remote Desktop Manager
Manual method
Deleting virtual folders can be done by manually editing each virtual folder, saving the changes and converting them into real folders. However, this process becomes time-consuming when dealing with a significant number of virtual folders, as it requires converting each one manually.
PowerShell method
Before proceeding with the PowerShell method, please take note of the following:
This method deletes all virtual folders in the workspace vaults.
Delete duplicate folders before running the PowerShell script from the new entry.
Launch Remote Desktop Manager as an administrator by right-clicking on the application and choosing Run as administrator.
Select the workspace vaults from which you want to convert all virtual folders in the navigation pane.
Add a new entry.
Go to Session – PowerShell to create a PowerShell session entry.
Name the entry and choose the folder in which you want to create it.
Set the entry to Embedded Script.
Click on Edit embedded script.
Add the following script:
# Check if Remote Desktop Manager PS module is installed if (-not (Get-Module Devolutions.PowerShell -ListAvailable)) { Install-Module Devolutions.PowerShell -Scope CurrentUser } $beforeAllGroups = Get-Date $vaults = Get-RDMVault foreach ($vault in $vaults) { Set-RDMCurrentRepository -Repository $vault $vaultname = $vault.Name Write-Host "Current Vault is $vaultname" # Get all entries' folder path $sessions = Get-RDMSession $allGroups = @() foreach ($session in $sessions) { # Split the group folder location for each shortcut $tempFolder = $session.Group $shortcuts = $tempFolder.split(';') foreach ($shortcut in $shortcuts) { $folder = $shortcut if ($folder) { $levels = $folder.split('\') $nblevels = 1 $Groupfolder = "" foreach ($level in $levels) { $name = $level if ($nblevels -eq 1) { $Groupfolder = $name } else { $Groupfolder = "$Groupfolder\$name" } $item = New-Object PSObject -Property @{ Name = $name Group = $Groupfolder Levels = $nbLevels } $allGroups += $item $nblevels++ } } } } # Get all folders that exist in the database $groups = Get-RDMSession | Where-Object { $_.ConnectionType -eq "Group" } $realGroups = @() foreach ($group in $groups) { # Split the group folder location for each shortcut $tempFolder = $group.Group $shortcuts = $tempFolder.split(';') foreach ($shortcut in $shortcuts) { $folder = $group.Group if ($folder) { $levels = $folder.split('\') $nbLevels = $levels.Count $name = $group.Name $item = New-Object PSObject -Property @{ Name = $name Group = $folder Levels = $nbLevels } $realGroups += $item } } } # Sort arrays and extract virtual folders $realGroups = $realGroups | Sort-Object -Property Levels, Name, Group -Unique $allGroups = $allGroups | Sort-Object -Property Levels, Name, Group -Unique $results = $allGroups | Where-Object { $realGroups.Group -notcontains $_.Group } $results = $results | Sort-Object -Property Levels, Name, Group -Unique # Convert virtual folders in the database foreach ($group in $results) { $name = $group.Name $folder = $group.Group try { $session = New-RDMSession -Name $name -Group $folder -Type Group -SetSession -ErrorAction Stop Update-RDMUI } catch { # Split the parent folder $tempFolder = $folder.Replace("\$name", '') $parents = $tempFolder.split('\') foreach ($parent in $parents) { try { $exist = Get-RDMSession -Name $parent -ErrorAction Stop } catch { $name = $parent $index = $parents.IndexOf($parent) $folder = "" for ($item = 0; $item -le $index; $item++) { if ($item -gt 0) { $folder += "\" } $folder += $parents[$item] } $session = New-RDMSession -Name $name -Group $folder -Type Group -SetSession Update-RDMUI Write-Host "Virtual folder $name has been successfully created in the database!" } } $name = $group.Name $folder = $group.Group $session = New-RDMSession -Name $name -Group $folder -Type Group -SetSession Update-RDMUI } Write-Host "Virtual folder $name has been successfully created in the database!" } } $afterCreatingGroups = Get-Date Write-Host "Time taken to convert virtual folders: $(($afterCreatingGroups).Subtract($beforeAllGroups).Seconds) second(s)"Click OK to apply the script.
Click OK the save the entry settings and close the window.
Click on Open Session to run the entry.
The script will now convert all virtual folders in the workspace vaults.
Last updated
Was this helpful?
