> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/convert-a-website-legacy-entry-to-a-website-entry.md).
# Convert a website (legacy) entry to a website entry
Follow the steps below to convert your ***Website (legacy)*** entry to a ***Website*** entry type in Remote Desktop Manager using [***Special actions***](https://docs.devolutions.net/rdm/commands/edit/edit-special-actions/).
To convert several entries at once, you can perform a batch conversion by searching by ***Connection type*** with the ***Advanced Search*** feature. If your entries are in multiple vaults, you can search using the broader ***Information*** connection type to include ***Website (legacy)*** entries. Note that this will also return other information-type entries, so additional filtering may be required. First make sure your vault(s) contain ***Website (legacy)*** entries, otherwise the entry type will not appear in the search options. Visit [Batch Edit](https://docs.devolutions.net/rdm/commands/edit/batch-edit/) for more information.
1. Select the entry you want to convert in the ***navigation pane***. It is possible to select multiple entries at once, provided they are of the same type.
2. Right-click the entry and select ***Edit – Edit (special actions)***. Alternatively, you can use the ***Ribbon*** by clicking on ***Edit (Special Actions)*** in the ***Batch*** section of the ***Edit*** tab.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB2076.png" alt=""><figcaption></figcaption></figure>
3. In the ***Web*** section, select ***Convert website (legacy)*** to ***Website*** and click ***Ok***.
   <figure><img src="https://cdnweb.devolutions.net/docs/RDMW4045_2024_1.png" alt=""><figcaption></figcaption></figure>
4. Click ***OK*** in the ***Batch action result*** window.
   <figure><img src="https://cdnweb.devolutions.net/docs/RDMW4047_2024_1.png" alt=""><figcaption></figcaption></figure>
Your entry has now been converted.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/convert-a-website-legacy-entry-to-a-website-entry.md?ask=<question>&goal=<endgoal>
