> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/convert-a-website-legacy-entry-to-a-website-entry.md).
# Convert a website (legacy) entry to a website entry
Convert Website legacy entries to the Website entry type in Remote Desktop Manager using the special actions batch conversion.
Follow the steps below to convert your ***Website (legacy)*** entry to a ***Website*** entry type in Remote Desktop Manager using [***Special actions***](/rdm/ribbon-menu-bar/edit/edit-special-actions.md).
As of RDM 2026.3, ***Website (legacy)*** entries also convert automatically on the next vault opening for Devolutions Cloud workspaces, or the next server restart for Devolutions Server workspaces.
1. Select the entry you want to convert in the ***navigation pane***. It is possible to select multiple entries at once, provided they are of the same type.
2. Right-click the entry and select ***Edit – Edit (special actions)***. Alternatively, you can use the ***Ribbon*** by clicking on ***Edit (Special Actions)*** in the ***Batch*** section of the ***Edit*** tab.
3. In the ***Web*** section, select ***Convert website (legacy)*** to ***Website*** and click ***Ok***.
4. Click ***OK*** in the ***Batch action result*** window.
Your entry has now been converted.
To convert several entries at once, you can perform a batch conversion by searching by ***Connection type*** with the ***Advanced Search*** feature. If your entries are in multiple vaults, you can search using the broader ***Information*** connection type to include ***Website (legacy)*** entries. Note that this will also return other information-type entries, so additional filtering may be required. First make sure your vault(s) contain ***Website (legacy)*** entries, otherwise the entry type will not appear in the search options. Visit [Batch Edit](/rdm/ribbon-menu-bar/edit/batch-edit.md) for more information.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/convert-a-website-legacy-entry-to-a-website-entry.md?ask=<question>&goal=<user_goal>
