> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/convert-a-legacy-certificate-entry-to-an-x.509-credential-entry.md). Agents can also search and read this documentation through its [MCP server](https://docs.devolutions.net/~gitbook/mcp).
# Convert a legacy certificate entry to an x.509 credential entry
Convert legacy certificate entries to X.509 credential entries in Remote Desktop Manager individually or in bulk using advanced search.
Learn how to convert a legacy certificate entry to an X.509 credential entry. You can also use ***Advanced search*** to find certificate entries and convert them in bulk.
{% hint style="warning" %}
It is strongly recommended that you back up your data before proceeding.
2. Press <kbd>Ctrl</kbd> and click the certificate entries you want to convert in the navigation pane.
3. Right-click the selection and select ***Edit*** – ***Edit (special actions)*** (or do the same in the ribbon).
4. In the ***Convert to*** section, select ***Convert to X.509 credential entry*** and click ***Execute***.
5. Enable ***Keep folder*** to retain the certificate in its current location during conversion; leave it disabled to move it to the root of the vault.
6. Click ***Convert***.
### Advanced search
2. Click ***View*** – ***Search*** – ***Advanced search*** in the ribbon (or <kbd>F11</kbd>).
3. Set a condition to ***Connection type*** and ***Certificate (.pfx, .crt, .cer, .p12, .pem)***.
4. Click ***Search***.
5. Press <kbd>Ctrl</kbd> and click to select the certificates.
6. Click ***Select in navigation pane***.
7. In the navigation pane, right-click the selection and select ***Edit*** – ***Edit (special actions)*** (or do the same in the ribbon).
8. In the ***Convert to*** section, select ***Convert to X.509 credential entry*** and click ***Execute***.
9. Enable ***Keep folder*** to retain the certificate in its current location during conversion; leave it disabled to move it to the root of the vault.
10. Click ***Convert***.
### See also
* [Advanced search](https://docs.devolutions.net/rdm/ribbon-menu-bar/view/search/advanced-search.md)
* [Configure certificate (X.509) credential entry type](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-certificate-x.509-credential-entry-type.md)
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/convert-a-legacy-certificate-entry-to-an-x.509-credential-entry.md?ask=<question>&goal=<user_goal>
