> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-the-remote-microsoft-management-console-mmc-using-dhcpmgmt.md).
# Configure the remote Microsoft Management Console (MMC) using dhcpmgmt
Configure a Command Line entry in Remote Desktop Manager to run the remote Microsoft Management Console using dhcpmgmt.msc.
You can configure an MMC snap-in console to run on any of your servers. The snap-in needs to support remote access.
### Settings
2. Create a new entry.
3. In Macros/Scripts/Tools, select the ***Command Line*** entry type.
4. Name the session DHCP.
5. Under the ***General*** tab, in the ***Run*** field, type *dhcpmgmt.msc /ComputerName $HOST$* ($HOST$ is the variable that will be replaced by the server name or IP address).
6. Under the ***Advanced*** tab, enable ***Run as Administrator***.
   <div data-gb-custom-block data-tag="hint" data-style="info" class="hint hint-info"><p>If you are running a Windows 64-bit edition, enable <em><strong>Run in 64-bit mode</strong></em> as well.</p></div>
7. Click ***Add*** to save your entry.
8. Verify that your sessions use the appropriate credentials to run the tool. In the ***Management Tools – Tools*** section of each session, make sure you have selected the proper credentials to be supplied.
| Option                  | Description        |
| Use default credentials | Use the credentials from the Windows session.        |
| Use session credentials | Use the same credentials as the session.        |
| Username and password   | Username, domain and password can be entered manually.        |
| Linked                  | Specify a set of credentials from a vault. Select the vault in the ***Vault*** list, then select the credential entry.                                                             |
| My personal credentials | Use [***My Personal Credentials***](https://docs.devolutions.net/rdm/ribbon-menu-bar/file/my-account-settings/my-personal-credentials.md) set in ***File – My account settings***. |
| Inherited               | [Inherits credentials](https://docs.devolutions.net/rdm/concepts/intermediate-concepts/inheritance.md) from a higher level entry.                                                  |
| Prompt for credentials  | Prompts for the credentials on use.        |
| My privileged account   | Use ***My Privileged Account*** set in ***File – My account settings***.        |
#### Snaps-ins
1. To run snap-ins, select your session and execute the Command Line entry type (DHCP) from the dashboard under ***Macros/Scripts/Tools***.
2. Execute Windows run.
3. Type Microsoft Management Console (MMC) and press enter.
4. Go to ***File - Add/Remove Snap-in.***
5. Select the snap-ins and click OK.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-the-remote-microsoft-management-console-mmc-using-dhcpmgmt.md?ask=<question>&goal=<user_goal>
