Configure Devolutions Password Manager multi-factor authentication
Remote Desktop Manager has the option to use Devolutions Password Manager to provide an additional security layer when the application starts.
Click on File – Settings – Security and select Require a TOTP validation (Devolutions Password Manager or Google Authenticator) in the Multi-factor authentication section. Then click on Configure to set up your TOTP validation.
Scan the QR code on your screen with Devolutions Password Manager to setup Remote Desktop Manager. Enter the Validation code provided by Devolutions Password Manager into Remote Desktop Manager.
Click Validate, then OK.
Relaunch Remote Desktop Manager to be prompted for the Devolutions Password Manager code.
See also
PreviousConfigure certificate x.509 credential entry type
NextConfigure Git commit signing with Remote Desktop Manager
Last updated
Was this helpful?
