Configure Barracuda add-on
Here is how you configure a Barracuda add-on in Remote Desktop Manager.
  1. Add a new entry and select Extension manager.
  2. Search Barracuda NG firewall and click Activate add-on.
  3. Close the window.
Remote Desktop Manager needs a path to the ngadmin_.exe to open Barracuda Firewall Admin. Barracuda Firewall must be properly installed on the computer.
  1. To do this, go to File – Option – Paths – Configure Installation Path.
  2. Search Barracuda NG Firewall. It is necessary to specify the folder where the file is located, override the default executable, and enter the name of the new executable with the .exe.
  3. Click OK.
The add-on is now fully configured.
Last updated
Was this helpful?
