> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-aws-dashboard-entry.md).
# Configure AWS dashboard entry
Configure an AWS Dashboard entry in Remote Desktop Manager to view IAM users, groups, and roles using access key or SSO login.
The AWS dashboard allows system administrators to securely connect to their AWS environment and visualize key IAM components directly within Remote Desktop Manager:
* IAM User groups and their memberships
* IAM Users and associated group policies
* IAM Roles and trust relationships
1. In Remote Desktop Manager, go to ***New Entry*** and select ***AWS Dashboard***.
2. In the ***Add*** – ***AWS Dashboard*** dialog, enter a ***Name*** for the entry.
3. Optionally, select a ***Folder*** to organize the entry.
4. Under the ***General*** tab, click the ***Authentication type*** dropdown.
#### Access key <a href="#access-key" id="access-key"></a>
1. Select ***Access key***.
2. Enter your ***Access key ID***.
3. Enter your ***Secret access key***.
4. Select a ***Region*** from the dropdown, or leave it as ***Default***.
To keep the access key in a credential entry instead, set ***Credentials*** to a mode such as ***Linked (vault)*** and select the credential entry. Its user name is used as the ***Access key ID*** and its password as the ***Secret access key***, so both fields are unavailable in the entry. Read more on [entry credentials options](https://docs.devolutions.net/rdm/ribbon-menu-bar/edit/entry-credentials-options.md).
#### SSO <a href="#sso" id="sso"></a>
1. Select ***SSO***.
2. Enter the ***Portal URL*** for your AWS SSO portal.
3. Select a ***Region***, or leave it as ***Default***.
4. Click ***...*** next to ***Account*** to select the AWS account.
5. Click ***...*** next to ***Role name*** to select the IAM role.
6. Click ***Add*** to save the entry.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-aws-dashboard-entry.md?ask=<question>&goal=<user_goal>
