Configure AnyDesk entry
AnyDesk entries allows users to access devices remotely on a range of operating systems, notably Windows, MacOS, Linux, Android, and iOS. By leveraging this integration, users benefit from all the features of AnyDesk, including file transfer, remote printing, session recording, integrated collaboration tools, and more.
To create an AnyDesk entry, right-click in the navigation pane and select New entry or click on the New entry button located in the content area (+ icon). Then, head over to the Session section, and select the AnyDesk entry under Remote connections.
This straightforward entry has only a few required fields. First, enter a Name, then specify the Host, which can also be selected from the domain’s computer list by clicking on the ellipsis button (...) next to the field, and enter a strong Password. Click on Add.
Last updated
Was this helpful?
