Configure an access code entry in Remote Desktop Manager
The Access code is a credential entry that gives a simplified interface to users, providing only the View Password and Copy Password actions.
Go to the workspace vault in which you want to create the Access code entry in the navigation pane.
Select Access code under New Entry – Credential Management – General.
Name the entry and select its folder.
Choose a password and click OK to close the window.
View Password and Copy Password are now available in the Dashboard under Actions.
PreviousConfigure a Windows Admin Center entry
NextConfigure an Azure Bastion entry in Remote Desktop Manager
Last updated
Was this helpful?
