> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-vpn-with-an-existing-remote-session.md).
# Configure a VPN with an existing remote session
Follow this procedure to configure and launch secure remote sessions through a VPN or Devolutions Gateway in Remote Desktop Manager.
### VPN
You must first create a VPN entry, then do the following:
1. Select the RDP entry.
2. Go in the properties of your RDP entry, under ***VPN/Tunnel/Gateway***.
3. Set ***Connect*** to ***Always connect***.
4. Set ***Type*** to ***VPN link***.
   <figure><img src="https://cdnweb.devolutions.net/docs/RDMW6116_2025_1.png" alt=""><figcaption></figcaption></figure>
5. Go under the ***Settings (VPN link)*** tab at the top.
6. Use the ellipsis (...) button to select the ***VPN*** entry you have created.
   <figure><img src="https://cdnweb.devolutions.net/docs/RDMW6117_2025_1.png" alt=""><figcaption></figcaption></figure>
7. Click ***Update*** to save and close the window.
8. Launch your RDP entry which will first open the VPN you have configured to establish the connection.
### Devolutions Gateway
You must first install [Devolutions Gateway](https://docs.devolutions.net/gateway/overview/what-is-gateway/), then do the following:
2. Go back in the properties of your RDP entry, under ***VPN/Tunnel/Gateway***.
3. Set ***Type*** to ***Devolutions Gateway***.
4. Go under the ***Settings (Devolutions Gateway)*** tab at the top.
5. Use the ellipsis (...) button to select the Devolutions Gateway.
6. Click ***Update*** to save and close the window.
7. Launch the RDP entry, which will first open the Devolutions Gateway to establish the connection.
#### See also
[Youtube- RDM Quick Tip - Launch remote sessions via a VPN or a Devolutions Gateway](https://www.youtube.com/watch?v=xaC_7hYE33M)<br>
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-vpn-with-an-existing-remote-session.md?ask=<question>&goal=<endgoal>
