Configure a VPN for multiple sessions
Remote Desktop Manager automates opening a VPN when launching a remote session. This configuration is well suited to situations where you need one VPN for a group of servers at a remote location. This procedure sets the VPN configurations on the folder and the entries inherit the settings.
Configure the VPN settings on the parent folder entry
Right-click the folder entry and open its Folder properties, then under the Connection section, click on VPN/SSH/Gateway.
In the Connect drop-down list, select how the VPN opens when you launch a remote session. We recommend choosing Connect if unable to ping/port scan on the folder. We will have to set each session entry to Inherited later.
OptionDescriptionNot enabled
The VPN does not open when the session is open.
Always connect
The VPN always opens when the session is open.
Connect manually
The VPN requires users to manually open the VPN before launching the session.
Remote Desktop Manager automatically tests if the host responds, if not the VPN opens.
Inherited
The VPN inherits the settings from the parent folder.
Ask for confirmation to connect
The VPN prompts for confirmation before opening.
Connect if network adapter not found
Remote Desktop Manager tests if the network adapter is installed and active, if not the VPN opens.
Prompt if unable to ping/scan
Remote Desktop Manager tests if the host responds, if not the VPN prompts for confirmation before opening.
Connect if HTTP status code isn't successful
Remote Desktop Manager sends an HTTP signal to the host, and opens the VPN if the host returns a status other than 200 (by default). It is also possible to set a custom status by clicking on the ellipsis button next to the connection option.
In the Type drop-down list, click on Session link.
In the Close drop-down list, select how the VPN closes at the end of a remote session.
OptionDescriptionOn session close
The VPN closes automatically when the session is closed.
Manually later
The VPN requires users to manually close the VPN entry when finished.
Confirm disconnect
The VPN prompts to close the VPN when the session is closed.
In the VPN group field, click the plus sign to add a new VPN group, then enter a name for it. This will ensure that the VPN only turns off when the last session is closed. See this YouTube video for a demonstration.
Optionally, define a credential method and enter credentials in the Credentials (VPN/Tunnel/Gateway) field. This can come in handy for team environments.
Click the Settings (Session link) tab.
In the Session drop-down menu, select the VPN entry you created by clicking Linked (vault) in the drop-down menu. You can also select Find by name (user vault) to search VPN created by users in their user vault.
Click Update to save.
Perform a batch edit to configure the session entries
Select the session entries in the parent folder while holding down the Ctrl key to select multiple entries at once.
Right-click on the selection, then click on Edit – Batch edit – Edit entries (General settings) Alternatively, the same path can be followed in the ribbon under the Edit tab.
From the left menu, under the Connection section, click on VPN/SSH/Gateway, and check the Override VPN box.
In the Connect drop-down list, select Inherited. Click OK.
Settings for specific situations
There are many options to accommodate a range of VPN types. Here are two common situations and options to make using the VPN more efficient.
Situation 1: You lose connection to the workspace when the VPN is active.
Follow the steps below to automate going offline when the VPN opens.
In the Advanced tab, check the Go offline on connection and Go online on disconnect after X sec options. In this last option, specify the number of seconds, then click OK.
Situation 2: The VPN is slow to connect.
Follow the steps below to change the time Remote Desktop Manager waits for the VPN to open.
In the Advanced tab, in the After execution, wait section, enter the time in seconds, then click OK.
See also
Last updated
Was this helpful?
