> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-supremo-entry-in-remote-desktop-manager.md).
# Configure a Supremo entry in Remote Desktop Manager
Remote Desktop Manager integrates with Supremo, empowering IT professionals to centralize and streamline Supremo remote sessions alongside all their remote connections and credentials within a unified and secure interface.
***Note***: Supremo requires an active RDP session to the targeted workstation to work properly.
### Install Supremo locally
1. Go to the Supremo official download page and download the [Supremo executable](https://www.supremocontrol.com/download-supremo/?_gl=1*6196m4*_up*MQ..*_ga*MTcyNDEzMTAuMTc0MTgwNTg4MQ..*_ga_VFT0VE8MKP*MTc0MTgwNTg4MC4xLjEuMTc0MTgwNjM3MS4wLjAuMA..*_ga_F8PCNH1FKK*MTc0MTgwNTg4MC4xLjEuMTc0MTgwNjM3MS4wLjAuMA..#download).
2. Double-click the downloaded `Supremo.exe` file.
3. Select ***Run Supremo*** when prompted.
### Install Supremo on the workstation
1. Open your RDP session in Remote Desktop Manager.
2. Install [Supremo](https://www.supremocontrol.com/download-supremo/?_gl=1*6196m4*_up*MQ..*_ga*MTcyNDEzMTAuMTc0MTgwNTg4MQ..*_ga_VFT0VE8MKP*MTc0MTgwNTg4MC4xLjEuMTc0MTgwNjM3MS4wLjAuMA..*_ga_F8PCNH1FKK*MTc0MTgwNTg4MC4xLjEuMTc0MTgwNjM3MS4wLjAuMA..#download) on the RDP session.
3. Run the `Supremo.exe` file.
4. Select ***Run Supremo*** when prompted.
5. Specify a password for the Supremo connection.
6. Click ***Accept*** to confirm settings.
### Configure Supremo entry in Remote Desktop Manager
1. In Remote Desktop Manager, go to ***Tools** - **Extensions manager***.
2. Navigate to the ***Session*** tab.
3. Locate and enable the ***Supremo*** add-on.
   <figure><img src="https://cdnweb.devolutions.net/docs/RDMW6082_2025_1.png" alt=""><figcaption></figcaption></figure>
4. Create a new entry and select ***Supremo***.
   ![](https://cdnweb.devolutions.net/docs/RDMW6084_2025_1.png)
5. Enter the session number and the password.
6. Click ***Add*** to save and close the window.
7. Open the Supremo entry.
8. Click on the ellipse button (**…**) next to the ***Installation path*** field.
9. Choose the folder where you downloaded the Supremo executable.
10. Once entered, the password should auto-inject for subsequent sessions.
#### See also
[Devolutions Blog - Spotlight on: Supremo, a new Remote Desktop Manager-integrated remote access solution](https://blog.devolutions.net/2025/05/spotlight-on-supremo-a-new-remote-desktop-manager-integrated-remote-access-solution/)
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-supremo-entry-in-remote-desktop-manager.md?ask=<question>&goal=<endgoal>
