Configure a Supremo entry in Remote Desktop Manager
Remote Desktop Manager integrates with Supremo, empowering IT professionals to centralize and streamline Supremo remote sessions alongside all their remote connections and credentials within a unified and secure interface.
Install Supremo locally
Go to the Supremo official download page and download the Supremo executable.
Double-click the downloaded
Supremo.exefile.Select Run Supremo when prompted.
Install Supremo on the workstation
Open your RDP session in Remote Desktop Manager.
Install Supremo on the RDP session.
Run the
Specify a password for the Supremo connection.
Click Accept to confirm settings.
Configure Supremo entry in Remote Desktop Manager
In Remote Desktop Manager, go to Tools - Extensions manager.
Navigate to the Session tab.
Locate and enable the Supremo add-on.
Create a new entry and select Supremo.
Enter the session number and the password.
Click Add to save and close the window.
Open the Supremo entry.
Click on the ellipse button (…) next to the Installation path field.
Choose the folder where you downloaded the Supremo executable.
Once entered, the password should auto-inject for subsequent sessions.
See also
Last updated
Was this helpful?
