> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-rustdesk-entry-in-remote-desktop-manager.md).
# Configure a RustDesk entry in Remote Desktop Manager
Configure a RustDesk entry in Remote Desktop Manager to access the open-source remote desktop tool using its ID and password.
RustDesk entries allow users to seamlessly access the open-source, self-hosted remote desktop management software directly in Remote Desktop Manager. Leverage the RustDesk integration in Remote Desktop Manager for secure remote control without complex deployment.
To create a RustDesk entry, right-click in the navigation pane and select ***New entry*** or click on the ***New entry*** button located in the content area (***+*** icon). Then, head over to the ***Session*** section, and select the ***RustDesk*** entry under ***Remote connections***.
This straightforward entry has only a few required fields; First enter a ***Name***, then specify the ***ID*** and ***Password*** of your RustDesk client. Click on ***Add***.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-rustdesk-entry-in-remote-desktop-manager.md?ask=<question>&goal=<endgoal>
