Configure a Passbolt entry
Passbolt is a password manager that enables teams to share passwords and secrets securely. It integrates with Remote Desktop Manager in the same way as other password managers, such as LastPass, 1Password, Bitwarden, and others.
Open Remote Desktop Manager.
Add a new entry.
Go to Credential management and select Passbolt.
To allow Remote Desktop Manager to communicate and authenticate with Passbolt, a few settings are required: the URL, UserID, passphrase, and private key.
URL
This is the address of the Passbolt server that hosts its API.
UserID
The UserID is a unique identifier that Passbolt uses to recognize the account attempting to authenticate. Retrieving this information requires a specific process. Access the Passbolt web application, select the user profile, and locate the UserID in the browser’s address bar.
Passphrase
When creating a Passbolt user, a passphrase must be set. This passphrase must be provided during authentication, similar to a password.
Private key
During account creation, Passbolt provides a private key. At this stage, Passbolt emphasizes the importance of this key, ensuring it is saved securely in a file for future use.
Once these details are entered, Remote Desktop Manager can communicate with Passbolt and display the directories and stored passwords within the system.
Last updated
Was this helpful?
