> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-devolutions-server-cross-vault-credential-sharing-entry.md).
# Configure a Devolutions Server cross vault credential sharing entry
Configure a Devolutions Server cross vault credential sharing entry in Remote Desktop Manager to share credentials between vaults or workspaces.
This topic covers how to share a credential from a different vault in the same Devolutions Server, or between two Devolutions Server workspaces.
### Creating a credential sharing entry
1. In Remote Desktop Manager select a Devolutions Server workspace and go into the desired vault.
2. Click on ***New Entry***.
3. Go to ***Credential Management*** – ***Password Management***.
4. Select Devolutions Server and click ***OK***.
5. Enter the ***Name***.
6. Fill the information in the ***General*** tab:
| SETTINGS                       | DESCRIPTION        |
| **Host**                       | The URL to Devolutions Server.        |
| **Use "My account settings"**  | Use the ***My acount settings*** Devolutions Server login set in ***File*** – ***Settings***. |
| **Use Windows authentication** | Use Windows authentication to log into Devolutions Server.                                    |
| **Username**                   | Use a set email to log into Devolutions Server.                                               |
| **Vault**                      | Click on the ellipsis button to select which vault to get the credential from                 |
7. Fill the information in the ***Entry*** tab:
| **Default (specific credential)** | This mode uses one specific credential.        |
| **Credential**                    | Click on the ellipsis button (**...**) to select which specific credential to share.        |
| **Name filtering**                | <p>Filters through the selected vault based on the search criterias to find an entry with a matching name. Choose between:<br>- <strong>Name</strong>: Enter the desired characters<br>- <strong>Mode</strong>: <strong>Contains the value</strong> or <strong>Exact match</strong><br>- <strong>Case sensitivity</strong>: <strong>No</strong> or <strong>Yes</strong></p> |
| **Always prompt with list**       | Always prompts the user with a list of the available credentials.        |
8. Click ***OK*** to save the changes and close this window.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-devolutions-server-cross-vault-credential-sharing-entry.md?ask=<question>&goal=<user_goal>
