> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-custom-download-path-for-devolutions-updater.md).
# Configure a custom download path for Devolutions Updater
Set a custom download path for Devolutions Updater in Remote Desktop Manager instead of using the default temp folder location.
Set a custom download path for Devolutions Updater instead of downloading in %TEMP%. It can be configured in two ways.
### Method 1: From the File menu
Go to ***File – Settings – Paths*** and enter a ***Custom download path*** in the field.
### Method 2: Directly in the updater
1. In the ***Help*** tab, click on ***Check for Updates***.
2. If Remote Desktop Manager can be updated, the ***Update Available*** pane will open. From there, click on ***Download***, then select one of these options:
   * ***Download this version and install now***: Devolutions Updater will open right now.
   * ***Download this version and install when application is closed***: Devolutions Updater will open after closing Remote Desktop Manager.
3. When the Devolutions Updater window appears, click on ***Options***.
4. Enter the ***Custom download path*** of your choice, then click ***Close***.
5. Click on ***Update*** and follow the standard update process.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-custom-download-path-for-devolutions-updater.md?ask=<question>&goal=<user_goal>
