> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-credential-redirection-entry-in-remote-desktop-manager.md).
# Configure a credential redirection entry in Remote Desktop Manager
The ***Credential Redirection entry*** enables autofill from any password manager and with a favorite Web browser.
### Create a Credential Redirection entry
1. Go to ***New Entry*** – ***Credential Management*** – ***Password Management*** – ***Credential Redirection*** to create a new ***Credential Redirection entry***.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB6040.png" alt=""><figcaption></figcaption></figure>
2. Enter a ***Name*** and choose a ***Folder***.
3. Enter a ***Name ID*** (case sensitive). This must be unique within your repository. It will be used to identify the credentials and will be exposed as a subdirectory of the URL used to intercept the credentials.
4. Select a specific browser, or use the default one.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB6072.png" alt=""><figcaption></figcaption></figure>
5. Click ***OK*** to save.
6. Open your new ***Credential Redirection entry***. Remote Desktop Manager displays the following informative dialog. The selected browser is launched for a URL that looks like this: `http://127.0.0.1:9999/LastPass%20redirection/login.aspx`.
   Notice the middle part is the ***Name ID*** entered previously. Depending on your configuration, the credentials are entered automatically, or you have to press a key combination to initiate your tool. Please refer to the documentation of your tool for more information.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB6073.png" alt=""><figcaption></figcaption></figure>
7. Enter your credentials to save in the browser. Remote Desktop Manager will now process your credentials.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB6074.png" alt=""><figcaption></figcaption></figure>
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB6075.png" alt=""><figcaption></figcaption></figure>
### Open a session using the Credential Redirection entry
1. Create a new entry, we will use an RDP entry for this example.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB6078.png" alt=""><figcaption></figcaption></figure>
3. For ***Credentials***, select ***Linked (vault)*** and then your newly created ***Credential Redirection entry***.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB6077.png" alt=""><figcaption></figcaption></figure>
4. Select your session then launch it. Remote Desktop Manager will display this informative dialog.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB6079.png" alt=""><figcaption></figcaption></figure>
5. In the web browser, enter your credentials and press ***Submit***. The page will be closed after a delay.
   <figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB6080.png" alt=""><figcaption></figcaption></figure>
The RDP session is launched and authentication is successful.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-credential-redirection-entry-in-remote-desktop-manager.md?ask=<question>&goal=<endgoal>
