> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-credential-redirection-entry-in-remote-desktop-manager.md).
# Configure a credential redirection entry in Remote Desktop Manager
Configure a Credential Redirection entry in Remote Desktop Manager to autofill credentials from any password manager into a web browser session.
The ***Credential Redirection entry*** enables autofill from any password manager and with a favorite Web browser.
### Create a Credential Redirection entry
1. Go to ***New Entry*** – ***Credential Management*** – ***Password Management*** – ***Credential Redirection*** to create a new ***Credential Redirection entry***.
2. Enter a ***Name*** and choose a ***Folder***.
3. Enter a ***Name ID*** (case sensitive). This must be unique within your repository. It will be used to identify the credentials and will be exposed as a subdirectory of the URL used to intercept the credentials.
4. Select a specific browser, or use the default one.
5. Click ***OK*** to save.
6. Open your new ***Credential Redirection entry***. Remote Desktop Manager displays the following informative dialog: "Remote Desktop Manager will now open a web page, please fill the credentials with your favorite tool and submit the form. This window will close automatically."
   The selected browser is launched for a URL that looks like this: `http://127.0.0.1:9999/LastPass%20redirection/login.aspx`.
   Notice the middle part is the ***Name ID*** entered previously. Depending on your configuration, the credentials are entered automatically, or you have to press a key combination to initiate your tool. Please refer to the documentation of your tool for more information.
7. Enter your credentials to save in the browser. Remote Desktop Manager will now process your credentials.
### Open a session using the Credential Redirection entry
1. Create a new entry, we will use an RDP entry for this example.
3. For ***Credentials***, select ***Linked***, then select the vault and your newly created ***Credential Redirection entry***.
4. Select your session then launch it. Remote Desktop Manager will display this informative dialog: "Remote Desktop Manager will now open a web page, please fill the credentials with your favorite tool and submit the form. This window will close automatically".
5. In the web browser, enter your credentials and press ***Submit***. The page will be closed after a delay.
The RDP session is launched and authentication is successful.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/configure-a-credential-redirection-entry-in-remote-desktop-manager.md?ask=<question>&goal=<user_goal>
