> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/clear-web-browser-cache.md).
# Clear web browser cache
Clear the web browser cache in Remote Desktop Manager by renaming or deleting the EO.WebBrowser.Cache and WebView2.Cache folders.
By deleting a folder, you are able to clear the web browser cache in the application folder of Remote Desktop Manager. Go to ***File – Settings – Advanced*** and click the ***Information*** tab to access the application folder. If your Remote Desktop Manager is in **Program Files**, you should find the ***EO.WebBrowser.Cache*** and ***WebView2.Cache*** folders in the **localappdata**.
1. Close your Remote Desktop Manager application.
2. In the application folder, locate the ***EO.WebBrowser.Cache*** and ***WebView2.Cache*** folders. Depending on your Remote Desktop Manager version, you may only have one of those folders.
   <div data-gb-custom-block data-tag="hint" data-style="info" class="hint hint-info"><p>If you do not find either of those folders, the folder where the configuration files are stored may have been changed using an <strong>override.cfg</strong> file. See <a href="https://docs.devolutions.net/rdm/getting-started/installation/client/configuration-file-location.md#override-the-default-path">Configuration file location</a> for more information.</p></div>
3. Rename or delete the folder(s). The best practice is to rename the folders, as in this case you do not lose any data.
4. Restart Remote Desktop Manager.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/clear-web-browser-cache.md?ask=<question>&goal=<user_goal>
