> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/cache-sharing-between-multiple-edge-sessions.md).
# Cache sharing between multiple Edge sessions
Configure cache sharing between multiple Microsoft Edge sessions in Remote Desktop Manager using language, SmartScreen, and profile settings.
The Edge cache is controlled by a few settings. This is a limitation of the EdgeView2 control, which requires a unique folder as opposed to defined settings. Trying to share caches with conflicting settings will prevent the EdgeView2 control from loading, thus leading to a blank screen.
Here are the settings that affect sharing a cache between multiple Website sessions using Microsoft Edge:
### In Remote Desktop Manager settings
1. ***Language code*** (in entry ***Properties*** – ***General*** – ***Advanced***).
   ![](https://cdnweb.devolutions.net/docs/RDMW6023_2026_1.png)
2. ***SmartScreen*** (in entry ***Properties*** – ***General*** – ***Settings***).
   ![](https://cdnweb.devolutions.net/docs/RDMW6025_2026_1.png)
3. Enable ***Single Sign-On with Windows accounts*** (***File*** – ***Settings*** – ***Entry types*** – ***Sessions*** – ***Website***).
   ![](https://cdnweb.devolutions.net/docs/RDMW6024_2026_1.png)
These settings need to be appended to the Microsoft Edge’s cache folder path. Here are some examples:
* `C:\Users{user}\AppData\Local\Devolutions\RemoteDesktopManager\WebView2.Cache\de\EBWebView`
* `C:\Users{user}\AppData\Local\Devolutions\RemoteDesktopManager\WebView2.Cache\SingleSignOn\EBWebView`
* `C:\Users{user}\AppData\Local\Devolutions\RemoteDesktopManager\WebView2.Cache\de\DisableSmartScreen\SingleSignOn\EBWebView`
### Profile
A profile then needs to be specified using the Edgeview2 control, which allows for various cache matching configurations.
1. ***Private mode***: This mode has its own private profile consisting of a profile name – if it exists – and the entry’s ID.
2. ***Profile name***: This profile allows sharing with all other sessions that match the three settings previously defined in Remote Desktop Manager and the profile name.
3. ***No profile name***: This profile allows sharing with all other sessions that match the three settings previously defined in Remote Desktop Manager without a profile name (it reverts to a hard-coded folder name).
### Clear cache on startup
With all this configured, the setting ***Clear cache on startup*** can be enabled. From then on, the cache will be cleared when first launching a session, and any subsequent sessions will not have theirs cleared until all are closed and a new one is launched.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/cache-sharing-between-multiple-edge-sessions.md?ask=<question>&goal=<endgoal>
