> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/background-vault-synchronization.md).
# Background vault synchronization
Enable background vault synchronization in Remote Desktop Manager to keep offline caches current automatically on first load or on demand.
Keeping your vaults up to date for offline access is crucial, as data can become outdated and offline caches may expire. This is where background vault synchronization helps by ensuring your offline data remains current. You can manually refresh your vaults using the sync icon, or have them automatically synced upon first load. With this feature, your offline caches are quickly synchronized, ensuring you're always prepared to work effectively without an internet connection.
### Enabling background vault synchronization
First this feature must be enabled by an administrator of the workspace.
Only available with SQL Server, Devolutions Server and Devolutions Cloud workspaces. For Devolutions Cloud workspace, this feature must be enabled via the website.
2. Select the [workspace](https://docs.devolutions.net/rdm/concepts/basic-concepts/workspaces.md).
3. Go to ***Administration -*** ***System settings - Cache/offline*** and check ***Allow sync all*** ***vaults*** ***(background)***.
4. Click ***Save*** to close the window.
Note that the ***Allow sync all vaults (background)*** setting can be overridden by a [GPO](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/apply-policies-gpos.md#general).
### Workspace configuration
1. Edit the workspace.
2. In the ***Advanced tab***, ***Sync all vaults (background)*** select between ***On first load*** and ***Manual*** on the ***Sync all vaults (background)*** drop-down menu.
   1. ***Default*** (Manual)
   2. ***Disabled***
   3. ***Manual:*** Synchronization must be manually triggered using the icon at the bottom left corner.
   4. ***On first load***: Remote Desktop Manager will automatically initiate a background ***vault*** synchronization upon the first load of the workspace, while still allowing the option for manual synchronization.
3. Click ***Save*** to close the window.
Learn how to synchronize [documentation](https://docs.devolutions.net/rdm/user-interface/content-area/dashboard/dashboard-tabs/documentation.md#synchronize-offline-documentation)and [document entries](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/synchronize-document-entries-for-offline-access.md) for [offline access](https://docs.devolutions.net/rdm/getting-started/workspaces/offline-mode/offline-read-and-write.md).
### Manual background vault synchronization
To perform a manual background vault synchronization, click on the ***Sync all available vault*** icon in the status bar (bottom-right) of Remote Desktop Manager.
The color turns orange when a background synchronization is in progress.
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/background-vault-synchronization.md?ask=<question>&goal=<user_goal>
