> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/automatically-detect-and-bypass-jump-host-for-direct-connections-in-local-network.md).
# Automatically detect and bypass jump host for direct connections in local network
Configure Remote Desktop Manager to automatically detect local hosts and bypass the jump host for direct connections on the same network.
A jump host acts as a gate between two trusted networks, allowing access, but only with the permission of the jump host.
However, when the computer is already on the same network as the host, going through the jump host is not needed, and the alternative is to disable the jump host or to use a direct connection (without jump host). Remote Desktop Manager can instead test the host first and use the jump host only when the host does not respond. This applies to entries that use the ***Jump host*** type in their ***VPN/tunnel/gateway*** settings.
1. Open the ***Properties*** of the entry.
2. Select ***Connection*** – ***VPN/tunnel/gateway***.
3. In the ***Connect*** list, select ***Connect if unable to ping/port scan***.
4. In the ***VPN provider*** list, select ***Jump host***.
5. In the ***Session*** field, select the jump host entry.
6. Click ***OK*** to save and close the window.
When the session opens, Remote Desktop Manager tests if the host responds. If the host responds, the session opens directly; if not, the session opens through the jump host.
By default, the test uses the host of the entry. To test another host or a specific port, click the ***Advanced settings*** button at the end of the ***Connect*** list and enter a ***Custom host*** or a ***Custom port***. To be asked before the jump host is used, select ***Prompt if unable to ping/scan*** in the ***Connect*** list instead. For all the settings of the section, see [VPN/tunnel/gateway](/rdm/knowledge-base/knowledge-base-articles/entry-settings/common-settings/vpn-tunnel-gateway.md).
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/automatically-detect-and-bypass-jump-host-for-direct-connections-in-local-network.md?ask=<question>&goal=<user_goal>
