> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/allow-open-multiple-connections.md).
# Allow open multiple connections
Remote Desktop Manager allows you to open multiple connections on the same host.
You can enable the ***Allow open multiple connections option*** in the ***Advanced*** Tab of an entry.
<figure><img src="https://cdnweb.devolutions.net/docs/RDMW6125_2025_1.png" alt=""><figcaption></figcaption></figure>
| Option | Description                                                           |
| Yes    | Allow open multiple connections will be active for this entry only.   |
| No     | Allow open multiple connections will be disabled for this entry only. |
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/allow-open-multiple-connections.md?ask=<question>&goal=<endgoal>
