Allow open multiple connections
Remote Desktop Manager allows you to open multiple connections on the same host.
You can enable the Allow open multiple connections option in the Advanced Tab of an entry.
Option
Description
Yes
Allow open multiple connections will be active for this entry only.
No
Allow open multiple connections will be disabled for this entry only.
Last updated
Was this helpful?
