Add web links in macro/script/tool sessions
Macros/scripts/tools sessions can be used to open web links in Remote Desktop Manager.
Create the embedded web link
Create a shared web session template.
Once the template is created, add a new Template entry in Macro/Script/Tool.
Assign the new template to your newly created Macros/Scripts/Tools session using the ellipsis button.
Make sure to check the Keep template host option.
Click Add to save the entry.
PreviousAdd elevated credentials to session entries
NextAllow access to your PC from outside your PC's network
Last updated
Was this helpful?
