> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/add-a-template-as-a-custom-tool.md).
# Add a template as a custom tool
Turn a Remote Desktop Manager template into a one-click custom tool that automatically applies its settings to the currently focused connection.
Get access to a one-click ***custom tool*** which would apply a ***template*** automatically to one of your connections in Remote Desktop Manager The main goal of this solution is to save you a few clicks since launching an entry with a ***template*** would require that you follow all these steps:
1. Select one of your entries.
2. Right-click on it.
3. Select ***Open with parameters***.
4. Select ***Open with a template***.
5. Choose the ***template*** you wish to use in the list.
The method below, will give you a quick access in the Remote Desktop Manager dashboard ***Macros/Scripts/Tools*** section of the entry. It will allow you to click on the ***custom tool*** and open the connection that currently has focus with the parameters specified in your ***templates***.
To use this method, you will first need to create a ***template*** under ***File - Templates.*** For more information, please consult this [link](https://docs.devolutions.net/rdm/ribbon-menu-bar/administration/templates.md).
The ***template*** that you will create (database template only) will need to have the option ***Available in Macros/Scripts/Tools*** enabled in the ***Template settings – Availability*** section for it to be shown in your ***dashboard***.
### Method
1. In the ***Ribbon***, go under ***Edit - New entry - Add macros/scripts/tools***.
2. Select ***Template*** in the ***Tool*** section and click ***OK***.
3. In the ***General*** tab, use the ellipsis button to select the ***template*** you created and click ***OK*** when done.
4. The ***template*** entry you just created can be found under the ***Macros/Scripts/Tools*** section of your entry ***dashboard*** when you select one of your entries in your ***navigation pane***.
All that remains is to apply the desired model.
### See also
* [Devolutions Academy – Add a template as a custom Tool](https://academy.devolutions.net/student/activity/2928818-add-a-template-as-a-custom-tool)
* [Devolutions Academy – Simplifying setup with entry templates and password policies](https://academy.devolutions.net/student/activity/3380088)
GET https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/add-a-template-as-a-custom-tool.md?ask=<question>&goal=<user_goal>
