> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/it/knowledge-base/troubleshooting-articles/amazon-s3-explorer-issues.md).
# Problemi con Amazon S3 Explorer
Risolva l'errore 403 Forbidden accesso negato di Amazon S3 Explorer concedendo le autorizzazioni ListAllMyBuckets e GetBucketLocation.
Amazon.S3.AmazonS3Exception: Access Denied ---> Amazon.Runtime.Internal.HttpErrorResponseException: The remote server returned an error: (403) Forbidden. ---> System.Net.WebException: The remote server returned an error: (403) Forbidden.
### Soluzione
Sono richieste le autorizzazioni ListAllMyBuckets e GetBucketLocation. La soluzione alternativa consiste nel modificare la regione impostandola su quella selezionata dal bucket.
GET https://docs.devolutions.net/rdm/it/knowledge-base/troubleshooting-articles/amazon-s3-explorer-issues.md?ask=<question>&goal=<user_goal>
