Délai d'expiration de la connexion SQL Server
Les délais d'attente de connexion avec un SQL Server peuvent prendre plusieurs formes. En voici quelques-unes des plus courantes :
System.Data.SqlClient.SqlException : Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
System.Data.SqlClient.SqlException (0x80131904): Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding. System.ComponentModel.Win32Exception (0x80004005): The wait operation timed out.
Microsoft.Data.SqlClient.SqlException (0x80131904): A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: TCP Provider, error: 0 - This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.)
Microsoft.Data.SqlClient.SqlException (0x80131904): Connection Timeout Expired. The timeout period elapsed while attempting to consume the pre-login handshake acknowledgement. This could be because the pre-login handshake failed or the server was unable to respond back in time. The duration spent while attempting to connect to this server was - [Pre-Login] initialization=5018; handshake=12;
Solution 1
Pour résoudre ce problème, la première approche à envisager est d'augmenter votre délai d'attente de connexion.
  1. Dans Remote Desktop Manager, allez dans Fichier – Espaces de travail et modifiez votre espace de travail Microsoft SQL Server en cliquant sur l'icône Modifier l'espace de travail.
  2. Dans l'onglet Avancé, augmentez le délai Délai d'attente de connexion.
  3. Enregistrez vos modifications.
Solution 2
Si l'ajustement de la durée du délai d'attente de connexion n'a pas résolu le problème, vérifiez les paramètres de votre pare-feu. SQL Server fonctionne sur des ports dynamiques, ce qui exige que les ports appropriés soient ouverts pour permettre une communication fluide entre Remote Desktop Manager et votre SQL Server. Pour savoir quels ports activer, veuillez consulter la section « Ports utilisés par le moteur de base de données » dans Configurer le pare-feu Windows pour autoriser l'accès à SQL Server.
Solution 3
Si vous continuez d'éprouver des problèmes de délai d'attente de connexion, la cause racine pourrait être liée à l'écouteur SQL ou aux groupes de disponibilité. Dans de tels cas, essayez de définir la valeur MultiSubnetFailover à True.
  2. Dans l'onglet Avancé, cliquez sur Plus de paramètres.
  3. Recherchez le paramètre MultiSubnetFailover et définissez sa valeur à True.
  4. Cliquez sur OK, puis enregistrez vos modifications.
Solution 4
Autres solutions possibles
Si les solutions mentionnées ci-dessus n'ont pas résolu le problème, d'autres correctifs potentiels se trouvent dans les articles Microsoft suivants :
N'hésitez pas à contacter notre équipe de soutien à la clientèle pour obtenir de l'aide supplémentaire.
Mis à jour
