> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/es/knowledge-base/troubleshooting-articles/sqlexception-column-parameter-or-variable.md).
# SqlException - columna, parámetro o variable
Solucione el error SqlException Cannot find data type datetime2 causado por el uso de SQL Server 2005, que no es compatible, actualizando a SQL Server 2012 o posterior.
`SqlException - Column, parameter, or variable #16: Cannot find data type datetime2.`
### Solución
Este error se produce cuando se utiliza SQL Server 2005, que no es compatible. Necesita SQL Server 2012 o posterior.
GET https://docs.devolutions.net/rdm/es/knowledge-base/troubleshooting-articles/sqlexception-column-parameter-or-variable.md?ask=<question>&goal=<user_goal>
