> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/es/knowledge-base/troubleshooting-articles/amazon-s3-explorer-issues.md).
# Problemas de Amazon S3 Explorer
Corrija el error 403 Forbidden de acceso denegado de Amazon S3 Explorer concediendo los permisos ListAllMyBuckets y GetBucketLocation.
Amazon.S3.AmazonS3Exception: Access Denied ---> Amazon.Runtime.Internal.HttpErrorResponseException: The remote server returned an error: (403) Forbidden. ---> System.Net.WebException: The remote server returned an error: (403) Forbidden.
### Solución
Se requieren los permisos ListAllMyBuckets y GetBucketLocation. La solución alternativa consiste en cambiar la región a la seleccionada por el bucket.
GET https://docs.devolutions.net/rdm/es/knowledge-base/troubleshooting-articles/amazon-s3-explorer-issues.md?ask=<question>&goal=<user_goal>
