> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/getting-started/workspaces/offline-mode/offline-read-and-write.md). Agents can also search and read this documentation through its [MCP server](https://docs.devolutions.net/~gitbook/mcp).
# Offline read and write
Add, edit, and delete Remote Desktop Manager entries while offline using Read/Write mode, then review and resolve sync conflicts once back online.
The ***Read/Write*** offline mode allows the user to add, edit and delete entries while the workspace is offline. Those changes are saved locally and synchronized with the workspace once it is back online.
{% hint style="warning" %}
Go online and synchronize your offline changes before upgrading Remote Desktop Manager from a version earlier than 2027.1. Offline changes that are not synchronized are lost after the upgrade. See [Offline mode](https://docs.devolutions.net/rdm/getting-started/workspaces/offline-mode.md) for more information.
See [Offline mode](https://docs.devolutions.net/rdm/getting-started/workspaces/offline-mode.md) to know which permissions to grant in order for this to work for each workspace.
Some functionalities are not available while offline, but the [user vault](https://docs.devolutions.net/rdm/user-interface/navigation-pane/user-vault.md) is still accessible.
### Offline edits workflow
1. Connect to the workspace, and click on ***File – Go offline***.
2. Make the desired edits and save them. Go back online by clicking on ***File – Go online*** once the changes are completed.
3. Accept or reject the offline changes in the ***Offline edits*** window. The ***Compare session modifications*** button allows for a side-by-side comparison of the changes.
4. Click on ***Ok*** once the changes have been accepted or rejected to satisfaction.
When conflicts occur, the user causing them must decide to accept or reject the changes. The different versions of the entry can be compared to view which changes has been made.
### Compare versions of an entry
Click the ***Compare session modifications*** button to compare the versions of a conflicted entry. Analyze the XML structure of the entry to decide to ***Accept*** or ***Reject*** the changes.
The content on the left represents the entry retrieved online, and the content on the right represents the local version of the entry edited in Offline mode.
GET https://docs.devolutions.net/rdm/getting-started/workspaces/offline-mode/offline-read-and-write.md?ask=<question>&goal=<user_goal>
