Required package for each PAM action
This article explains which package is required for each action in Devolutions Privileged Access Management (PAM).
Workforce password management
Gives users access to Devolutions Server and Devolutions Cloud web interfaces. Use is limited to assigned shared vaults and PAM vaults, with entry usage restricted by assigned permissions. Manual password reset and heartbeat check are unavailable in PAM vaults. Users do not have access to PAM management and cannot launch sessions.
Remote access management
Gives users access to Devolutions Launcher, allowing them to use sessions configured with PAM accounts through Devolutions Gateway.
Remote desktop management & IT operations
Gives users access to Remote Desktop Manager and Devolutions Launcher to launch sessions configured with PAM accounts. Users can use Devolutions Server and Devolutions Cloud through Remote Desktop Manager. Manual password reset and heartbeat check are unavailable in PAM vaults. Users do not have access to PAM management.
Privileged access management
Gives users access to Remote Desktop Manager, Devolutions Launcher, and PAM management, including all PAM functionalities.
See also
Last updated
Was this helpful?
