> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/pam/knowledge-base/knowledge-base-articles/methods-for-using-personal-pam-accounts-in-remote-desktop-manager.md).
# Methods for using personal PAM accounts in Remote Desktop Manager
Configure Remote Desktop Manager to automatically launch sessions with a personal PAM account or prompt users to select one at session launch.
You can configure Remote Desktop Manager Windows to automatically launch sessions using a PAM account from your user vault, or to prompt you with a list of available PAM accounts at launch. The first two methods rely on creating a ***Devolutions Server privileged account*** entry and linking it to your session. The third method uses a PAM account stored directly in your user vault.
#### Use PAM account to automatically launch sessions
2. Go to your user vault.
3. Create a ***Devolutions Server privileged account*** entry.
4. Enter the server information.
5. Select your dedicated PAM account from the list.
6. Click ***Add*** to save the entry.
7. Go to the shared vault and select your session. For this example, we will use an RDP session.
8. Navigate to the ribbon of Remote Desktop Manager and click ***Edit*** – ***User specific settings*** – ***Overwrite credentials*** – ***Linked***, then select your user vault in the vault list. From there, select the ***Devolutions Server privileged account*** you just created.
9. Open your RDP session. You’ll be prompted to check out the selected PAM account, and the session will automatically launch using this account.
Note: ***User-specific settings*** are applied only for your user.
#### Prompt for PAM accounts in sessions
1. In your shared vault, create a ***Devolutions Server privileged account*** entry.
2. Create a ***Devolutions Server privileged account*** entry.
3. Enter your Devolutions Server URL.
4. Enable both:
   * ***Use my account settings***
   * ***Always prompt with list***
5. Click ***Add*** to save the entry.
6. Navigate to ***File*** – ***My account settings*** – ***Devolutions Server privileged account***, and confirm that your username is correctly entered.
7. Select an RDP session, for example, and go to ***Edit*** – ***Credentials.***
8. Select ***Linked***, then select the vault and the ***Devolutions Server privileged account*** entry you created.
9. When you double-click the RDP session, a list of available PAM accounts will appear.
Only the accounts that match your username in ***My account settings*** and that you have access to will be shown.
#### Find a PAM account of your user vault by name
Your user vault can hold PAM accounts directly: standalone accounts, certificate accounts, and accounts managed by a global PAM provider. See [PAM accounts in user vaults](https://docs.devolutions.net/pam/pam-with-devolutions-server/pam-accounts-in-user-vaults.md).
1. Store the PAM account in your user vault, or have it imported there from an account discovery configuration.
2. In a shared vault, right-click a session, for example an RDP session, and select ***Properties***.
3. In the ***General*** view, select ***Linked*** in the credentials dropdown menu, then select the user vault in the vault list next to it.
4. Enter the name of the PAM account in the field below. Variables can be used in the name, so a single session can find a different account for each user.
5. Update the entry to save your changes.
If a credential entry in your user vault has the same name, Remote Desktop Manager uses the credential entry instead of the PAM account.
#### Related topics
* [Devolutions Academy – Set up user vault credentials in Remote Desktop Manager](https://academy.devolutions.net/student/activity/2925723-set-up-user-vault-credentials-in-remote-desktop-manager)
* [Set up user vault credentials in Remote Desktop Manager](https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/set-up-user-vault-credentials-in-remote-desktop-manager)
* [Specific settings](https://docs.devolutions.net/rdm/ribbon-menu-bar/edit/specific-settings)
* [Find credentials by name in the user vault](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/find-by-name-user-vault-entry-credentials-option)
GET https://docs.devolutions.net/pam/knowledge-base/knowledge-base-articles/methods-for-using-personal-pam-accounts-in-remote-desktop-manager.md?ask=<question>&goal=<user_goal>
