External Secrets Operator
External Secrets Operator integrates with Devolutions Server for secret management.
The values in this guide (e.g., your-application-id) are placeholders, replace them with the specific values of your environment.
Authentication
Devolutions Server authentication uses Application ID and Application secret credentials.
Creating an application identity in Devolutions Server
  1. Log into your Devolutions Server's web interface.
  2. Navigate to Administration – Applications identities.
  3. Click Add (+) to create a new application.
  4. Configure the application with the permissions required to access the desired vaults and entries.
  5. Save the Application ID and Application secret.
Creating the Kubernetes secret
Create a Kubernetes secret containing your Devolutions Server credentials using the following script:
kubectl create secret generic dvls-credentials \
  --from-literal=app-id="your-application-id" \
  --from-literal=app-secret="your-application-secret"
Creating a SecretStore
Field
Description
serverUrl
The URL of the Devolutions Server instance (e.g., https://devolutions-server.example.com)
vault
The name or UUID of the vault from which to fetch secrets. When omitted, the vault must be specified in the secret key using the legacy <vault-id>/<entry-id> format. This field is optional.
insecure
Set to true to allow plain HTTP connections. Not recommended for production. This field is optional.
auth.secretRef.appId
Reference to the secret containing the Application ID.
auth.secretRef.appSecret
Reference to the secret containing the Application secret.
For ClusterSecretStore, ensure you specify the namespace in the secret references.
Referencing secrets
Entries can be referenced by UUID or name:
Format
Example
Entry UUID
7c9e6679-7425-40de-944b-e07fc1f90ae7
Entry name
db-credentials
Entry name with folder path
infrastructure/databases/db-credentials
Folder path with backslashes
infrastructure\databases\db-credentials
The vault is configured in the SecretStore's vault field (name or UUID), so the key only needs to identify the entry.
Folder paths
If an entry is inside a folder, you can include the folder path before the entry name. Both forward slashes (/) and backslashes (\) are accepted as path separators:
Forward slashes do not need escaping and are recommended for simplicity.
The folder path is optional. Without a path, the provider searches across all folders in the vault. If multiple entries share the same name in different folders, you can either specify the folder path or use the entry UUID to disambiguate.
Name-based lookups resolve the name to a UUID at runtime via an API call. If multiple credential entries match, an error is returned. For write-heavy scenarios (frequent PushSecret operations), prefer UUID references to avoid the extra lookup per operation.
You can find UUIDs in the Devolutions Server web interface by viewing the entry properties.
Supported credential types
Devolutions Server supports multiple credential types. The provider maps each type to specific properties:
Credential type
Devolutions Server entry type
Available properties
Default
Credential
username, password, domain
Access Code
Secret
password
API Key
Credential
api-id, api-key, tenant-id
Azure Service Principal
Credential
client-id, client-secret, tenant-id
Connection String
Credential
connection-string
Private Key
Credential
username, password, private-key, public-key, passphrase
All entries also include entry-id and entry-name metadata properties.
Examples
Fetching individual properties
To fetch specific properties from a credential entry:
Using dataFrom to extract all fields
When using dataFrom.extract, all available properties from the credential entry will be synced to the Kubernetes secret.
Push secrets
The Devolutions Server provider supports pushing secrets back to Devolutions Server:
Note: Push secret updates an existing entry's password field. The entry must already exist in Devolutions Server.
Limitations
  • GetAllSecrets: The find operation for discovering secrets is not currently supported.
  • Custom CA Certificates: Custom TLS certificates for self-signed Devolutions Server instances are not yet supported. Use the SSL_CERT_FILE environment variable as a workaround.
  • Certificate entries: Certificate entry types (Document/Certificate) are not currently supported. Only Credential entries are supported.
Troubleshooting
Authentication errors
If you receive authentication errors:
  1. Verify the Application ID and Secret are correct.
  2. Ensure the application has the necessary permissions in Devolutions Server.
  3. Check that the Devolutions Server server URL is accessible from your Kubernetes cluster.
Entry not found
If an entry cannot be found:
  1. Verify the vault and entry references are correct (UUID or name)
  2. Ensure the application has at least read access to the vault
  3. Check that the entry exists and is a Credential or Secret type entry
  4. Ensure the application has at least read, view password, and connect (execute) permissions on the entry
Multiple entries found
If you receive a "multiple entries found" error when using name-based references, it means more than one credential entry shares the same name in the vault. Use the entry UUID instead of the name to target the correct entry.
Last updated
Was this helpful?
