> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/pam/knowledge-base/knowledge-base-articles/automatically-checkin-pam-account-when-closing-the-entry.md).
# Automatically check in PAM account when closing the entry
Configure automatic check-in behavior for PAM accounts when closing an entry in Devolutions Server and Remote Desktop Manager settings.
Privileged access management (PAM) in Devolutions Server and Remote Desktop Manager provides several check-in behaviors for what happens when you close an entry.
### Devolutions Server
Open Devolutions Server web interface and go to the ***Preferences*** section located in the account menu.
| Options                                                       | Description        |
| **Automatically check in PAM account when closing the entry** | <ul><li>Default: Use the default check-in setting, the value of which can be changed in <em><strong>Administration</strong></em> – <em><strong>Privileged access management (PAM)</strong></em> – <em><strong>Default settings</strong></em>.</li><li>Always prompt: Enforce prompting for check-in confirmation regardless of the default settings.</li><li>Check-in automatically: Automatically check-in the PAM account without prompting when closing the entry.</li><li>Don't check-in automatically: Disables automatic check-in, requiring manual intervention to check in the PAM account.</li></ul> |
### Remote Desktop Manager
Open Remote Desktop Manager and go to ***Account information*** and click ***User preferences.***
![](https://cdnweb.devolutions.net/docs/RDMW6013_2023_2.png)
Select an option from the ***Automatically check in PAM account when closing the entry*** drop-down menu.
![](https://cdnweb.devolutions.net/docs/RDMW6055_2025_3.png)
| **Automatically check in PAM account when closing the entry** | <ul><li>Always prompt: Enforces prompting for check-in confirmation regardless of the default settings.</li><li>Check-in automatically: Automatically check-in the PAM account without prompting when closing the entry.</li><li>Don't check-in automatically: Disables automatic check-in, requiring manual intervention to check in the PAM account.</li></ul> |
GET https://docs.devolutions.net/pam/knowledge-base/knowledge-base-articles/automatically-checkin-pam-account-when-closing-the-entry.md?ask=<question>&goal=<endgoal>
