Automatically check in PAM account when closing the entry
Privileged access management (PAM) in Devolutions Server and Remote Desktop Manager provides several check-in behaviors for what happens when you close an entry.
Devolutions Server
Open Devolutions Server web interface and go to the Preferences section located in the account menu.
Options
Description
  • Default: Use the default check-in setting, the value of which can be changed in Administration – Privileged access management (PAM) – Default settings.
  • Always prompt: Enforce prompting for check-in confirmation regardless of the default settings.
  • Check-in automatically: Automatically check-in the PAM account without prompting when closing the entry.
  • Don't check-in automatically: Disables automatic check-in, requiring manual intervention to check in the PAM account.
Open Remote Desktop Manager and go to Account information and click User preferences.
Select an option from the Automatically check in PAM account when closing the entry drop-down menu.
Options
Description
  • Always prompt: Enforces prompting for check-in confirmation regardless of the default settings.
Last updated
Was this helpful?
