Ansible module
This Ansible module allows you to authenticate with Devolutions Server and fetch server information, vaults, and secrets.
Features
Authenticate with Devolutions Server using application identities.
Fetch server information, vault lists, or specific secrets.
Flexible support for static secrets or fetching all secrets in a vault.
Requirements
Ansible 2.18
Python
requestslibraryA Devolutions Server application identity (create at
{your-dvls-url}/administration/applications).The application must have permissions to fetch the desired secrets.
Last updated
Was this helpful?
