> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/pam/knowledge-base/how-to-articles/apply-password-rotation-to-pam-provider-credentials.md).
# Apply password rotation to PAM provider credentials
Apply scheduled password rotation to Devolutions Server PAM provider credentials by linking them to a managed PAM vault account.
This workflow is used to apply a PAM managed account as a PAM provider identity. The objective is to have a ***password rotation*** applied to the PAM provider's credentials.
To have Devolutions Server create and rotate this account automatically, enable self-rotation on the provider instead. Refer to [Configure a PAM provider to rotate its own password](https://docs.devolutions.net/pam/knowledge-base/how-to-articles/configure-a-pam-provider-to-rotate-its-own-password.md).
A [PAM vault](https://docs.devolutions.net/pam/pam-with-devolutions-server/pam-vaults.md) must be set up before following the steps below.
1. Open Devolutions Server.
2. Go to ***Administration*** – ***Privileged access*** – ***Providers*** to create a provider.
3. In the provider window, select ***Custom*** in the ***Credential type*** drop-down menu.
4. Open a PAM vault.
5. Add a ***Domain user*** to the PAM vault by clicking ***+ icon (Add)***.
6. Manually populate the fields and select the ***provider***.
7. Enter the ***username*** and the ***current password***.
8. Apply the ***Password rotation schedule***.
9. Click ***Add***.
10. The account is out of sync (not verified yet). ***Right-click*** on the account.
11. Select ***Check*** ***Synchronization Status***.
12. The synchronization status should turn green.
13. Go back to ***Administration*** – ***Privileged access*** – ***Providers***.
14. Select your provider and change the ***Custom credentials*** for ***Linked credential***.
15. The ***Privileged account*** window opens.
16. Select the account added beforehand.
17. Click ***OK*** to save and close the window.
GET https://docs.devolutions.net/pam/knowledge-base/how-to-articles/apply-password-rotation-to-pam-provider-credentials.md?ask=<question>&goal=<user_goal>
