> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/integrations/devops-ci-cd/terraform.md).
# Terraform
Use the Terraform provider for Devolutions Server to manage vaults, folders and entries, and to read server resources from your Terraform configuration.
Terraform integrates with Devolutions Server, a workspace type of Remote Desktop Manager, through the Devolutions Server Terraform provider, which manages your server instance from Terraform configuration files. It does not use a Remote Desktop Manager entry type. The ***Terraform*** document entry of Remote Desktop Manager is not related to this integration: it stores a Terraform configuration file (.tf) and opens it in a text editor.
## Prerequisites
* A Devolutions Server instance, version 2026.x. See [Devolutions Server](https://docs.devolutions.net/server).
* [Terraform](https://developer.hashicorp.com/terraform/install) version 1.0, or version 1.10 to use ephemeral resources.
* A Devolutions Server application identity, or an API key, with the permissions that match your configuration: ***View content*** on the vaults and the ***View***, ***View password*** and ***View sensitive information*** entry permissions to read entries; the ***Add***, ***Edit*** and ***Delete*** entry permissions to manage entries; ***Edit permissions*** for `dvls_entry_permissions`; the ***Add***, ***Edit*** and ***Delete*** permissions under ***Vault management*** for `dvls_vault`; the ***View*** permission under ***Role*** for the `dvls_administrative_role` data source; and the ***Manage*** permission under ***Assignments*** for `dvls_administrative_role_assignment`.
* [Go](https://go.dev/doc/install) version 1.26, only to build the provider from source.
## What you can do
* Authenticate to Devolutions Server with the application ID and application secret of an application identity, or with an API key.
* Manage vaults, folders, credential entries (username and password, secret, API key, SSH key, connection string and Azure service principal), certificate entries, entry permissions and administrative role assignments with resources.
* Read users, user groups, vaults, administrative roles, applications, host and website entries, credential entries and certificate entries with data sources, such as `dvls_entry_website`.
* Read the secret of a credential or certificate entry with an ephemeral resource.
The provider is a work in progress. Breaking changes can occur between releases.
## Configure Terraform
1. Sign in to the Devolutions Server web interface.
2. Go to Administration – Management – Application identities, click ***Add*** (the + button) to create an application identity, and give it the permissions listed in the prerequisites. Note its ***Application ID*** and ***Application Secret***.
3. Declare the provider in your Terraform configuration:
   ```hcl
   terraform {
     required_providers {
       dvls = {
         source = "devolutions/dvls"
   provider "dvls" {
     base_uri   = "https://your-dvls-instance.com/"
     app_id     = "your-app-id"
     app_secret = "your-app-secret"
4. Replace the values of `base_uri`, `app_id` and `app_secret` with those of your instance and application identity. To use an API key, set `api_key` instead of `app_id` and `app_secret`.
5. Alternatively, leave the credentials out of the configuration and set the `DVLS_APP_ID` and `DVLS_APP_SECRET` environment variables, or `DVLS_API_KEY`.
## Use Terraform
1. Add a resource or a data source of the provider to your configuration, for example:
   ```hcl
   data "dvls_entry_website" "example" {
     id = "id-of-website-entry"
2. Run [`terraform init`](https://developer.hashicorp.com/terraform/cli/commands/init) to install the provider.
3. Run [`terraform plan`](https://developer.hashicorp.com/terraform/cli/commands/plan) to preview the result.
4. Run [`terraform apply`](https://developer.hashicorp.com/terraform/cli/commands/apply) to apply the configuration.
For the resources and data sources available, see the [Terraform Registry](https://registry.terraform.io/providers/Devolutions/dvls/latest).
## Integration level
Terraform is an integration level 2 – Moderate support integration. See [Integration levels](https://docs.devolutions.net/resources/integration-levels).
#### See also
* [Application identities](https://docs.devolutions.net/server/web-interface/administration/user-and-security-management/applications-identities)
* [Terraform entry settings](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/entry-settings/terraform.md)
* [terraform-provider-dvls on GitHub](https://github.com/Devolutions/terraform-provider-dvls)
GET https://docs.devolutions.net/rdm/integrations/devops-ci-cd/terraform.md?ask=<question>&goal=<user_goal>
