> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/integrations/devops-ci-cd/kubernetes.md).
# Kubernetes
Sync Devolutions Server secrets into Kubernetes with the External Secrets Operator, reference vault entries and push updated passwords back to the server.
Kubernetes integrates with Devolutions Server, a workspace type of Remote Desktop Manager, through the External Secrets Operator, which reads entries from a Devolutions Server vault and creates Kubernetes secrets from them. It does not use a Remote Desktop Manager entry type.
## Prerequisites
* A Devolutions Server instance whose URL is reachable from your Kubernetes cluster. See [Devolutions Server](https://docs.devolutions.net/server).
* A Kubernetes cluster with the [External Secrets Operator](https://external-secrets.io/latest/introduction/overview/) installed.
* A Devolutions Server application identity with the ***View content*** permission on the vault, and the ***View*** and ***View password*** entry permissions on the entries to sync. To use a `PushSecret`, it also needs the ***Edit*** entry permission on the target entry.
## What you can do
* Authenticate to Devolutions Server with an application ID and application secret stored in a Kubernetes secret.
* Reference entries by universally unique identifier (UUID), by name, or by name with a folder path (`/` or `\` as separator).
* Sync Credential entries and Secret entries. The provider maps each credential type to its properties: `username`, `password`, `domain`, `api-id`, `api-key`, `tenant-id`, `client-id`, `client-secret`, `connection-string`, `private-key`, `public-key` and `passphrase`.
* Fetch one property, or extract all the properties of an entry into a Kubernetes secret. The `password` property is returned when no property is specified.
* Push the value of a Kubernetes secret to the password field of an existing Credential entry of the Default or Access Code subtype with a `PushSecret`.
{% hint style="warning" %}
The `find` operation (GetAllSecrets) and Certificate entries are not supported. Custom certificate authority (CA) certificates are not supported yet; use the `SSL_CERT_FILE` environment variable for a self-signed Devolutions Server.
## Configure Kubernetes
1. Sign in to the Devolutions Server web interface.
2. Go to Administration – Management – Application identities, click ***Add*** (+) and, in ***Role assignments***, assign a role that includes ***View content*** on the vault, such as ***Vault member***. Give the application identity the entry permissions, for example through its ***User groups***.
3. Save the ***Application ID*** and the ***Application Secret***.
4. Create a Kubernetes secret that contains them:
   ```bash
   kubectl create secret generic dvls-credentials \
     --from-literal=app-id="your-application-id" \
     --from-literal=app-secret="your-application-secret"
5. In the same namespace as the secret, create a `SecretStore` that points to the Devolutions Server instance:
   ```yaml
   apiVersion: external-secrets.io/v1
   kind: SecretStore
   metadata:
   spec:
     provider:
       dvls:
         serverUrl: 'https://devolutions-server.example.com'
         vault: 'my-vault'
         auth:
           secretRef:
             appId:
               key: app-id
             appSecret:
               key: app-secret
6. Set `serverUrl` to the URL of your Devolutions Server instance and `vault` to the name or UUID of the vault to read. If `vault` is omitted, use the `<vault-id>/<entry-id>` format in each secret key.
7. For a `ClusterSecretStore`, specify the `namespace` in the secret references.
## Use Kubernetes
1. In the same namespace, create an `ExternalSecret` that refers to the store with `secretStoreRef`:
   ```yaml
   kind: ExternalSecret
   metadata:
   spec:
     refreshInterval: 1h
     secretStoreRef:
       kind: SecretStore
     target:
       creationPolicy: Owner
     data:
       - secretKey: password
         remoteRef:
           key: 'db-credentials'
           property: password
2. Set `key` to the UUID or the name of the entry, with an optional folder path such as `infrastructure/databases/db-credentials`. Use the UUID when several entries share the same name, or when the name contains `/` or `\`.
3. To sync all the properties of an entry, use `dataFrom` with `extract` instead of `data`.
4. Apply the manifest. The operator creates the Kubernetes secret and refreshes it at the `refreshInterval`.
5. To push a value back, create a `PushSecret` with `remoteKey` set to the name or the UUID of an existing entry of the Default or Access Code subtype.
## Integration level
Kubernetes is an integration level 2 – Moderate support integration. See [Integration levels](https://docs.devolutions.net/resources/integration-levels).
#### See also
* [Application identities](https://docs.devolutions.net/server/web-interface/administration/user-and-security-management/applications-identities)
GET https://docs.devolutions.net/rdm/integrations/devops-ci-cd/kubernetes.md?ask=<question>&goal=<user_goal>
