> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/integrations/devops-ci-cd/ansible.md).
# Ansible
Use the Ansible collection for Devolutions Server to authenticate with an application identity, fetch server information, read secrets and write credentials.
Ansible integrates with Devolutions Server, a workspace type of Remote Desktop Manager, through the `devolutions.dvls` Ansible collection, which authenticates with an application identity to fetch server information, vaults and secrets, and to create or update credentials. It does not use a Remote Desktop Manager entry type.
## Prerequisites
* A Devolutions Server instance. See [Devolutions Server](https://docs.devolutions.net/server).
* Ansible 2.18.
* The Python `requests` library.
* A Devolutions Server application identity that can read the vault content: the ***View content*** permission on the vault, and the ***View*** and ***View password*** entry permissions on the secrets to fetch. To create or update credentials with `devolutions.dvls.create_secret`, it also needs the ***Add*** (create) or ***Edit*** (update) entry permission.
## What you can do
* Authenticate with the application ID (the `app_key` parameter) and the application secret of an application identity.
* Fetch server information and the list of vaults with the `devolutions.dvls.fetch_server` module.
* Fetch secrets by name or ID from a vault, or fetch all the secrets of a vault, with the `devolutions.dvls.fetch_secrets` module.
* Create or update a credential entry with the `devolutions.dvls.create_secret` module. Only the Credential type with the Default subtype is supported.
* Retrieve one field of a credential, or the whole credential, with the `devolutions.dvls.secret` and `devolutions.dvls.secret_full` lookup plugins, by name, path or universally unique identifier (UUID).
## Configure Ansible
1. Sign in to the Devolutions Server web interface.
2. Go to Administration – Management – Application identities (`{your-server-url}/administration/applications`) and click ***Add*** (the + button) to create an application identity.
3. Give the application identity access to the vault: in ***Role assignments***, assign a role that includes ***View content*** on the vault, such as ***Vault member***, and give it the entry permissions, for example through its ***User groups***. Note its ***Application ID*** and ***Application Secret***. The collection calls the application ID `app_key`.
4. Install the `devolutions.dvls` collection. See [Installing collections](https://docs.ansible.com/ansible/latest/collections_guide/collections_installing.html).
5. Optionally, set the `DVLS_APP_KEY` and `DVLS_APP_SECRET` environment variables to the application ID and the application secret. Only the lookup plugins read environment variables, and they also read `DVLS_SERVER_BASE_URL` and `DVLS_VAULT_ID`. The modules take `app_key` and `app_secret` as parameters, for example `lookup('env', 'DVLS_APP_KEY')`.
## Use Ansible
1. In a playbook, add a `devolutions.dvls.fetch_secrets` task with `server_base_url`, `app_key`, `app_secret` and `vault_id`.
2. Add a `secrets` list with the `secret_name` or the `secret_id` of each secret to fetch, or omit `secrets` to fetch all the secrets of the vault.
3. Register the result and read a field with `{{ value['name-or-id'].password }}`. Use the field name of the credential type, such as `username` or `password`.
4. To read the server information and the vaults, add a `devolutions.dvls.fetch_server` task with `server_base_url`, `app_key` and `app_secret`.
5. To write a credential, add a `devolutions.dvls.create_secret` task with `vault_id` and a `secret` that has a `secret_name` and a `value`.
6. To read a field inline, use `lookup('devolutions.dvls.secret', 'prod-database', field='username')`. The `field` is `password` when omitted.
7. Run the playbook with [ansible-playbook](https://docs.ansible.com/ansible/latest/cli/ansible-playbook.html).
## Integration level
Ansible is an integration level 2 – Moderate support integration. See [Integration levels](https://docs.devolutions.net/resources/integration-levels).
#### See also
* [Application identities](https://docs.devolutions.net/server/web-interface/administration/user-and-security-management/applications-identities)
* [ansible-dvls on GitHub](https://github.com/Devolutions/ansible-dvls)
GET https://docs.devolutions.net/rdm/integrations/devops-ci-cd/ansible.md?ask=<question>&goal=<user_goal>
