System requirements for Devolutions Cloud
To use Devolutions Gateway, your system must meet the following requirements.
Hardware requirements
Minimal implementation (1 to 5 concurrent sessions)
Small implementation (5 to 15 concurrent sessions)
Medium implementation (15 to 75 concurrent sessions)
Large implementation (More than 75 concurrent sessions)
2 vCPUs 4 GB RAM
4 vCPUs 8 GB RAM
8 vCPUs 16 GB RAM
Deploy multiple Devolutions Gateway instances.
Software requirements
Windows 10 (version 20H2, 21H1, and 21H2), or Windows 11 (version 21H2)
Windows Server 2016, 2019, 2022, or 2025 with .NET Framework 4.8
Ubuntu Linux 18.04, 20.4, 22.4, and later
Red Hat Enterprise Linux (RHEL) 8 and later
Rocky Linux 8 and later
PowerShell 7 (required only for using the Devolutions Gateway PowerShell module on Linux)
The Devolutions Gateway must be able to reach Devolutions Cloud at the network level.
Certificate requirements
Devolutions Gateway supports TLS 1.2 and TLS 1.3 as well as the following cipher suites:
AES_256_GCM_SHA384
AES_128_GCM_SHA256
CHACHA20_POLY1305_SHA256
ECDHE_ECDSA_AES_256_GCM_SHA384
ECDHE_ECDSA_AES_128_GCM_SHA256
ECDHE_ECDSA_CHACHA20_POLY1305_SHA256
ECDHE_RSA_AES_256_GCM_SHA384
ECDHE_RSA_AES_128_GCM_SHA256
ECDHE_RSA_CHACHA20_POLY1305_SHA256
Last updated
Was this helpful?
