> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/gateway/knowledge-base/troubleshooting-articles/devolutions-gateway-side-by-side-installation-method-not-found.md).
# Devolutions Gateway side-by-side installation method not found
When installing Devolutions Gateway on the same machine as Devolutions Server (side by side installation), this error can trigger in the installation logs.
Method not found:'Void System.Management.Automation.Runspaces.InitialSessionState.set\_ExecutionPolicy(Microsoft.PowerShell.ExecutionPolicy)'.
### Solution
As Devolutions Gateway requires at least PowerShell version 5.1, please update PowerShell to that version to fix the issue. Then start over the Devolutions Gateway installation.
GET https://docs.devolutions.net/gateway/knowledge-base/troubleshooting-articles/devolutions-gateway-side-by-side-installation-method-not-found.md?ask=<question>&goal=<endgoal>
